alguém já instalou algo assim?
Creio que seja algo tipo o Tech2, mas nesse caso ele só le as informações do carro. Eu queria pra ter algumas informações passando numa tela, DVD por ex. Olhem esse produto. Tem um video no youtubiu que o cara aumenta até o volume. Tá 53 doletas e eu já comprei na Deal, demora, mas chega
ELM327 Bluetooth OBD-II Wireless Transceiver Dongle
Manufacturer's product description:
bluetooth ELM327 is the newly developed wireless scan tool. It supports all OBD-II protocols
• Works with all OBD-II compliant vehicles
• Wireless (Bluetooth)
• Software included for Palm, PDA
• Software included for Windows PC
• Software included for Windows Smartphone
• Supports ISO 9141, KWP2000
• Supports SAE J1850
• Supports CAN bus
Functions:
• Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
• Clear trouble codes and turn off the MIL ("Check Engine" light)
• Display current sensor data, including:
• Engine RPM
• Calculated Load Value
• Coolant Temperature
• Fuel System Status
• Vehicle Speed
• Short Term Fuel Trim
• Long Term Fuel Trim
• Intake Manifold Pressure
• Timing Advance
• Intake Air Temperature
• Air Flow Rate
• Absolute Throttle Position
• Oxygen sensor voltages/associated short term fuel trims
• Fuel System status
• Fuel Pressure
• Many others...
http://www.dealextreme.com/p/elm327-blu ... ngle-16921
