me ajudem, montando som alpine
peubz
Registrado em: Sábado 04 2007f Agosto 2007 10:26:51 AM
Mensagem por peubz »
Bom dia a todos,
Tenho um kit duas vias, 6x9 e um sub d 12 alpine...
ja instalei os falantes mas deixei o sub de lado para a escolha de um modulo mono bom... que aguente mesmo, nao manjo mto d som... as especificacoes... preciso de ajuda
o modelo do sub e: sws 1222d (sub 12 300rms) alpine
especificacoes:
Car Speaker Type: Component
Elements: 1-Way
Car Speaker Function: Subwoofer
Nominal Power Handling: 300 Watt RMS
Technical Features
Peak Power Handling: 900 Watt
Frequency Response: 26 Hz - 1 kHz
Sensitivity: 89 dB
Impedance: 2 ohm (Dual Coil)
Components
Woofer Material: Composite
Surround Material: Santroprene
Mounting
Top Mounting Depth: 6.5 In.
Miscellaneous
MPN: sws-1222d
Product ID: 21853013
More Information
Type-S speakers are designed to deliver big bass whether using the built-in power of a head unit or a large external amplifier. The Linear Drive Magnet, a dual radial magnet with a two-gap, one-voice coil structure, enables the Type-S woofers diaphragm to increase linear movement over a larger frequency range. The result is lower distortion even during long stroke at high volume. The woofers center-mounted Wave Guide aligns sound waves for more precise reproduction of the sound and sound image.
desculpa galera, nao achei a configuracao em portugues, to procurando vi 1 vez em 1 site... se achar posto
agradeco a ajuda pra qm responder ae... qual modulo aguenta d boa esse sub e da uma boa performance?
abracos...
